speediq99's avatar
speediq99
Explorer II
Mar 19, 2022
90 gal. Aux fuel tank below bed rails. Help.
Hello,
I am looking for a 90g. aux transfer fuel tank that sits below bed rails on Ram 3500.
RDS has a couple but their gas cap sits an inch or so too high making a tonneau cover not possible. It seems like the options I found are either tall rectangular (cannot use cover) or deep rectangular (30 inches of bed gone). Anyone found something tall and thin that works with a cover?
MC
  • No particular reason other than if I am going to use the bed might as well go big. I can always use 60 or 90 on a pinch.
    It actually looks like 60g with a tool box fit well and takes as much room as 90 without one. I just prefer the extra 30 gallons to the toolbox.
    MC
    BurbMan wrote:
    Stock tank is 36 gals, if you went with a 60 gal you would triple your range...Why 90 gals?
  • That might be the best option. It looks like adding a bit more depth and either shrinking or recessing the cap would have been enough. I am just surprised the missed it by an inch or so in most trucks. Covering this liquid gold is important these days.
    MC
    wanderingbob wrote:
    It is a matter of math , ninety gallons requires a large amount of volume . I wonder if you could alter the ninety gallon tank and recess the lid ?
  • Stock tank is 36 gals, if you went with a 60 gal you would triple your range...Why 90 gals?
  • It is a matter of math , ninety gallons requires a large amount of volume . I wonder if you could alter the ninety gallon tank and recess the lid ?
