sunline1
Sep 10, 2013Explorer
93 S10 4 wheel drive problem "UPDATE"
have a 4.3 ltr. automatic, s10 pickup (93) with the 4 wheel drive selector on the floor it has a shift "lever", as opposed to the ones with the switch mounted on the dash (button).
Its not been drived for a couple of years. I'm wantiong to start usin g it. the 4 wheel drive worked fine the last time i drove it a few years ago.
when i put the shifter on the floor into 4 wheel high or low setting the little round indicator light comes on, but the diagram does not light up the front 2 wheeels as it use to and the 4 wheel drive does not work.
If i put the selector to 4 wheel "low" its shifts to the 'very" low range but also no 4 wheel drive.
any comments thoughts suggestions appreicated.
Vaccum actuator under battery box has a slit in the rubber looks like thats the problem.
Any input on how to replace it would be appreciated. The are 2 bolts thru the fender liner,but how does it disconneft from the cable etc. Thanks
