Grit_dog
Aug 14, 2021Trailblazer
Front axle has nothing to do with it, once you realize that all or nearly all of the weight is on the rear axle. To be fair, a reg cab may put some weight on the front depending on the camper. The only reason to change Axle is to get rid of the TTB axle. For the obvious reasons around that thing.
Obviously you’re planning on supporting suspension mods for the camper. Do it right and I’d go up to 3500lbs or so loaded. Obviously the lighter it is, the more nimble it is though.
