joerg68
Aug 23, 2021Nomad III
Shaving off a few lbs here or there will not save you in my opinion.
Removing the awnings may make a difference, as their weight is far up. But it will leave you with a number of holes that need to be plugged and sealed.
Removing a little weight that is down low will not make much of a difference.
If you do get the camper, you could try to compare how it handles with empty tanks vs. full.
Get the actual axle weights, drive the thing, and work from there. Chances are, it will handle OK as-is.
