Peg_Leg
Sep 27, 2013Explorer
My 94 had plastic valves that were the same color as the lines. If it's in a dark corner it would be easy to mistake it for a elbow. The drain will only work if the valve is turned 90° to the correct side. So try turning yous to the other side. Mine was so hard to turn I cut a slot in a PVC pipe to fit over it. If you don't have any grip drill a hole through the other end to slip a rod into. I ended up using a marker on the floor so I could remember which way to turn it. I've got a photographic memory, when I saw the mark I remembered.
