garyhaupt
May 19, 2015Explorer
A Bigfoot bites it
In Kelowna, BC this morning. http://globalnews.ca/news/2006424/camper-explodes-in-kelowna-walmart-parking-lot/ Gary Haupt
HMS Beagle wrote:pjay9 wrote:
Photomike, I am not certain about BF's but on boats the joint is usually stronger than the hull or the deck... the joints are mostly likely glued with a sealant then glass/resin taped to make it watertight, thus it become strong...now that is in a good boat. Cheap boats are glued with sealant and then a flimsy rub rail is pop riveted on the joint on the outside...nasty leak prone and not strong, but probably stronger than the rest...so I am not surprised the joints held is my point! But you may be correct! JMHO!!
That is why I have an all welded alloy boat!
Unfortunately, as good as Bigfoot is, and as much as I love mine, it is built far cheaper than a cheap boat. Not sure there is even sealant in there, it is just an overlapped seam with sheet metal screws driven through a flimsy aluminum rub rail. This is the RV industry after all....
