uintafly
Apr 15, 2014Explorer
AirForceAngler wrote:
Can't help you with the tub, but there is a thread on here recently about modifying the plumbing to draw water from the drain location of the fresh water tank. This helps you to get almost all of the water out for use. Basically, you can thread a "t" into the drain, put a petcock on one end and connect the pump draw tube to the top side of the "t".
That's a great idea. It will be a little more of a project though becuase I have an enclosed underbelly.
Also some of you mentioned you can add antifreeze directly to the pump. That would be nice for sure. I will have to check that tonight and if not wil linstall the kit this fall.
44,056 PostsLatest Activity: May 04, 2014
