Gdetrailer wrote:
LJAZ wrote:
Stromberg Carlson makes exactly what you're describing. It's called a bike bunk and runs about $200 or so. Or if you're into fabbing it probably wouldn't be too hard for you to copy.
X2!
Found on Amazon HERE for $179
Pricey?
Yes, but no need for you to "reinvent the wheel" when it is ready to buy and bolt on.. By the time you buy the materials, cut, weld, bolt together you will nearly have the same amount in material and your time.. Almost not worth the effort to fab up a homemade version..
Doesn't seem bad at all, I spent that much for a front hitch and then another $140 for the bike carrier, though mine carries 4 bikes and had the advantage of returning some weight to the front wheels instead of adding more hitch weight to the rear.
