JoeChiOhki's avatar
JoeChiOhki
Explorer II
Dec 28, 2014
A Kamper Rebirth - Planning - Propane Compartment (page 3)
Well, as mentioned, my old KIT hasn't seen the road since her big adventure in 2012 and is showing signs in several spots of structural buckling due to injuries sustained during that trip and leaks that formed during the two years of idle time since her last time on the road.
I had originally planned to take her partially apart, and repair what's broken, but the more I look at it, the more I'm leaning towards starting over as many had suggested in the past.
Since I'm planning to build her from the ground up, I decided the best idea was to start with a well known set of plans, that come with instructions and full-size assembly sheets, that you basically lay the parts out on to help in assembly.
I will be using the plans for the Glen-L - Everglade 11' side-entry as the base for the rebuild.
Exterior
Interior - Floor plan
Thanks to the heavy details and dedicated threads on the Amerigo rebuilds, I am also considering adding a Snap-N-Nap to the rear of the base Glen-L after making necessary changes to the design to allow of the additional leveraging load.
The biggest expense will likely be in purchasing new aluminum siding to replace what I can't reuse off the original camper.
I plan to glue and KREG join all the parts instead of using the stapling method that the camper was originally built with.
Areas where changes in the design will likely occur are the corners for increase structural rigidity at the jack attachment points, and the placement of things like the propane tanks.
I may utilize fiberglass wall paneling in some ares on the exterior to cut aluminum expenses down, as I'm not interesting in Filon and Fiberglass epoxy doesn't cure too well in the wet, cool, oregon winter weather.
