nomad297
Apr 23, 2015Explorer
Terryallan wrote:matthewijenkins wrote:.
Well, you guys nailed what is a happening, and that's me being a little intimidated to hold up traffic. I certainly thought about it. But I live on a busy street in Atlanta. at the edge of my house is a traffic light and on the other side of that the name changes from Road to Highway and is four lanes. And like nomad, many are going over speed limit. If I could pull up and back right in, I wouldn't mind holding up traffic. But if I had to go back and forth a few times to get it right, I think it could be really stressful. Plus I have a tree on one side of the driveway entrance and a flower bed that drops about 1 foot on the other.
The trailer dolly is something I never considered. Will think about that. And I think going to an empty parking lot to practice is a great idea. I'm sure by this fall I'll be a 'pro' and can back into the drive but just feel more comfortable for now being on my own property. However, last time turning around was so aggravating that I may just choose the aggravation of buttheads honking horns as less stressful.
Nomad I wish I could see what you mean exactly. Do you pull up past your drive? or you said just TO your drive that you then turn perpendicular in the road toward the center lane? When I posted originally, I was looking for tips on how to angle the truck with the trailer so when you stop and put it in reverse, you'll be perfectly set up to begin turning in the direction you need to. Any practical tips? Or perhaps I should just go practice.
I really do appreciate the notion that it's OK to make people wait. That helps me. Though I may try it in the yard one more time...
Pass your drive as close as you can get to on the side of the street it is on. As the TV passes. Turn away from it. Go until the rear of the TT lines up with your drive. As you bring the TV to a stop turn again so that the TV is at the angle to the TT you need to push the rear of the TT farther toward your drive,. Put it in reverse, and slide on in. Backing is always easier if you can get the TT lined up with the hole.
I have to back out of the road, thru the drive at an angle, go between a tree, and a flower garden, only 10' apart. Then turn to back down beside the house, and turn again to go thru a gate, and then turn the other way to back under the TT shed. Getting out of the road is the easy part.
This is exactly what I do.
Bruce
44,070 PostsLatest Activity: Aug 05, 2026
