TheDave
Apr 23, 2014Explorer
About to pull the trigger on this combo. Thoughts?
I thought I would update everyone. I picked this up on Friday from RV R US in Ohio. What a great place. Absolutely love this setup as I have it below. Weighed the setup after filling up with gas and an empty camper. Here is the weights I received. Steer Axle 3100 lb, Drive Axle 3780, trailer axle 4980, Gross Weight of 11,860. The yellow sticker on the door of the camper stated 5820 lb. Here it is all hitched up.
Back in this post I talked about looking for a travel trailer. Well I think I am about to end up with the following and would appreciate any advice or criticism on this configuration. Especially the weight distribution piece. I have the truck and love it and can not wait to be towing with it.
2014 Silverado 1500
Trailering & Payload 6.2L EcoTec3 V8 engine 4WD
Curb Weight 5370 lbs
Max Payload 1805 lbs
Max GVWR 7200 lbs
Max Conventional Trailering, 3.73 Rear Axle 11800 lbs
GCWR, 3.73 Rear Axle 17700 lbs
Spring Axle Capacity
Front Gross Axle Weight Rating 3950 lbs
Rear Gross Axle Weight Rating with 3.73 Rear Axle 4100 lbs
Grey Wolf 26DBH
Dry Hitch Weight 740 lbs.
Unloaded Vehicle Weight 5,750 lbs.
GVWR 7,740 lbs.
Cargo Carrying Capacity 1,952 lbs.
Exterior Length 31' 7"
Exterior Height 10' 5"
Exterior Width 97"
Fresh Water Capacity 50 gal.
Gray Water Capacity 41 gal.
Black Water Capacity 31 gal.
Awning Size 15 ft
EQUAL-I-ZER 90-00-1000 10,000/1000.
Thanks for taking your time to read this and provide me with your advice.
Regards,
David
2014 Silverado 1500
Max GVWR 7200 lbs
Grey Wolf 26DBH
GVWR 7,740 lbs.
Exterior Width 97"
Awning Size 15 ft
Regards,
David
