Camper_Jeff___K
Jul 15, 2022Navigator
3 tons wrote:StirCrazy wrote:3 tons wrote:
I have a similar set-up (at 400a/h LFP and 660w) and get the temptation but in the vagaries of the real world harvest, not too sure it’ll always pencil out -
In theory something like this: a gallon of propane has about 91,400 BTU’s, while 325w (ac power) at say a more conservative 75% duty cycle (considering local and inverter losses…) would equal 5850w over 24hrs equals 15.6 hrs refer operation per gallon of propane or 78 hrs per 5 gal tank…Just saying…
3 tons
Im not sure what your trying to say, but my fridge in my camper is a old one where the burner stays on all the time and I can easily let it go 3 months running 24/7 on a single 5 gal tank. once I start it up in the spring it stays going all summer until I winterize it in the fall, so three years now it has done this. I do this with my 5th wheel also and same thing, I fill my bottles in the spring and they don't get filled untill winter when I am doing inclimate camping. the 5th wheel does have a DSI large fridge, but it has 7lb bottles.
Well, in retrospect it does seem oddly high but was only a rapid back of the napkin calc..
However, I believe converting BTU’s into watts is the proper way to draw conclusions…
3 tons
Your calculations are probably pretty close. I have not done a solid 24 hour test yet. My feeling is it may be a losing battle trying to maintain the charge in the batteries with the fridge going 24 hours on electric. I think the fridge would deplete down to 10% charge overnight on the second or third day. I will do that test in a couple weeks when I'm on the road in the camper to moniter the conditions. If it was 4 AM and the batteries were down to 20 or 25%, I would end the test there knowing the batteries will not supply enough power till the sun came up high enough to begin supplying sufficient regenerative current. Even if I decide to do this during the daytime, it's still a winner.
44,071 PostsLatest Activity: Aug 30, 2026
