zulu52's avatar
zulu52
A/C and a generator
I am out of my area of expertise.
I am thinking about getting a Honda EU 3000.
Before I asked any questions here I knew I would have to have the BTU rating and AMP draw on my A/C unit.
I have a RV Products 9000 Series, Model 9201-776, A/C unit.
None of my paperwork has the info.
I can't find the info on line either.
Any ideas how I find out the AMP draw on this unit?
As I understand it, the AMP draw is what I need to be able to match up to the voltage output of the generator.
Please correct me if I'm wrong.
I have searched the subject here on RV.NET and read what I could find.
I don't know that I want to deal with two inline 2000's.
Once again, this is not my area of expertise.
Thanks,
Zulu
  • Thanks for all the input.
    I pull a trailer most of the time so the size of the generator is not an issue.
    The EU3000 could also come in pretty handy at home during outages to keep the refrigerator/freezer and a few lights going.
    I don't think it would run a home A/C unit.
    Zulu
  • In answer to the question, yes, any 3000 watt class of generator should suffice and while the various 2000 watt gennys will work in varying circumstances with or without the soft start caps, the larger units will be running with a lower load as a percentage of capacity. Since you specifically mentioned the Honda, it will likely be quieter than a Honda 2000 which if it does carry the load will be running at near full capacity.
  • It's not the running amperage that matters it the starting amperage. Also called locked rotor amps and inrush current. This is the amperage required to get the compressor moving from a dead stop. Even though this takes less than a second the power supply will need to be large enough to overcome the "locked rotor amps" LRA is usually 6-7x or more that of running amperage.
    The 3000 watt generator should have no problem starting any rv roof unit.
    As mentioned above you don't need a unit that big just for the air if you install a soft start cap. A 2000 watt generator will deliver 15 amps or so, more than the a/c needs. It may not be enough to get the unit started though without an upgrade to the start capacitor. We installed a micro-air in our new camper. They work great.
    https://www.microair.net/products/easystart-364-3-ton-single-phase-soft-starter-for-air-conditioners
  • You can get away with a Honda 2200i, and a MicroAir installed on your AC.
  • Do a google or similar search for your product. I think you will find several sources of info for it. If it is a 9200 BTU unit it will normally pull less than 12 amps so the gen you are considering should provide more than enough reserve power to run it.
  • The motor plate attached somewhere on the a/c unit should have both the starting load and the running load. Kayteg1 is correct regarding actual vs design but unless something is significantly wrong, they will be close to the same.
  • The only way to find amp your AC draws is putting a gauge on it.
    The factory btu ratings are having very loose tolerances.
    I had 15k Carrier running at full blast with less than 9 amp.
    On my TC the AC takes 6.7 amp to run.
    Than from the million topics on the subject you should know that is it starting load that require hefty generator that counts.
