Reddog1 wrote:
Unless cost is no object, I would go with the twin generators. They are the most versatile of your choices. They will run what you have with the minimum money spent, light enough to move around, and will work great when you go back to a TC.
Ditto.
Twin Honda 2000s have a higher continuous rating than the Honda EU3000i
Each 2000 has a 1600 watt continuous rating (total of 3200 watts)
The EU3000i has a continuous rating of 2600.
Versatility and ease of moving them around is why I went twins.
Most of the time I only take one of mine.
I also did a home build of an extended run 5 gallon fuel tank.  It will get a work out next weekend at the NW Overland Rally.
