deltabravo wrote:
I also did a home build of an extended run 5 gallon fuel tank.
I couldn't see the point in spending more money on an "application specific" extended run fuel tank, which is a outboard motor fuel tank with quick disconnect hoses.
I took a fuel jug I already had and adapted it to work.  I can still use it for other things, unlike an outboard motor jug/tank.
My hose is now set up with a T fitting and a second fitting so I can run them both from the fuel jug.
This photo isn't a good representation of proper use.  I usually sit the fuel jug higher than the generator so I get a better siphon / gravity feed going.
The replacement fuel caps for the generators are available on Ebay.
cap, drain extender and magnetic dip stick
