eddd's avatar
eddd
A/C and Generator Questions
I've now have a toy hauler but my years with the truck camper forum makes me sure ya'll are better informed on this than anyone.
Back in the day when I had my Lance I switched out my A/C unit to a Coleman Polar Cub 8000 so I could have A/C using my Honda 2000i.
My toy hauler has the same problem, an over-sized A/C unit. (The living section is only 16' with no slides.) Up until now this has not been an issue since I moved to Utah and I'm at a comfortable elevation when camping so there has been no need for A/C...until now.
I also use the toy hauler to transport my track motorcycles to tracks that are located in desert areas of Nevada and southern California where the A/C would be great between track sessions.
I understand the Polar Cub 8000 is no longer available and now the Coleman Mach 8 is the smallest unit available from Coleman. Will the Mach 8 run on a single Honda 2000i?
Assuming it will, I'll still be close to the price of a second Honda 2000i. So it might make more sense sense to go that route and parallel their outputs and stay with with I have since space with the toy hauler isn't the concern it was with the Lance.
Ideas? Suggestions? Alternatives? What am I missing in my analysis?
Thanks
  • The 11000 BTU Coleman Mach 1 Power Saver in my NL8-11 will run using my Honda 2000i
  • The second gen-set would be nice. Since you're not worried about the extra weight, that would be the way I would go. With a TC, I'd go the other way. Have a great summer.
    The 9200, yes, the other 2 models, no.
