Old-Biscuit wrote:
Evap coil is enclosed/sealed/insulated from outside air (otherwise the hot outside air would suck up all the cold air).
Remove return air filter.look inside and you will see evap coil.
Well, then the insulation must stink on mine. If I put on the blower when it's cold outside, I get some pretty cold air coming out of the vents, just as if the compressor was running.
The hot oustide air doesn't suck up all the cold air because the cold is being generated by the evaporation of the refrigerant. And hotter air is being blown out the other end of the system at the condenser coil. If that system isn't running, it'll scavenge heat from anywhere.
rockhillmanor wrote:
I'm still stuck on WHY anyone would want 'any' noise white or otherwise at night when RV'ing. :H
CLICK HERE Type in 13000 as the frequency, and press play. Now turn the volume as loud as it goes on your speakers. This is what I live with 24/7/365. I need white noise or I can't sleep. It's called tinnitus. And it can drive you crazy.
