When I'm at home, I use an adapter and plug my TT into a 20 amp outlet. I've heard that you shouldn't run your A/C when only plugged into 20 amps, but the breaker for the A/C in the TT is only a 20 am...
We have guest in now and are plugged into a dedicated 20 amp circuit. We are running Ac it will cut off when gets to temp but won't cut on. Would this be a voltage issue or thermostat malfunction?
