ac cools good at night but at mid day compressor cycles of and on about every 10 minutes and don't cool very well and has started tripping main breaker every once in a while,,,, cleaned the evaporator...
Need to check voltage and amp draw against the name plate, if high then the winding are bad, that's if voltage is 115 to 120. Be sure shore power is getting a good connection at both ends.
