chopper5670
May 28, 2013Explorer
ac problems
ac cools good at night but at mid day compressor cycles of and on about every 10 minutes and don't cool very well and has started tripping main breaker every once in a while,,,, cleaned the evaporator...
prichardson wrote:
With a clean filter and evap. coil it should not freeze up at either fan setting when the thermostat is at a reasonable setting. Low fan will do a better job of removing humidity which is a big factor in the southern states. The lower the humidity the warmer it can be and you still feel comfortable. If you try to cool to 65 you will likely have problems reguardless of fan speed.
