yillb
Jul 06, 2017Explorer
jyrostng wrote:
Those units blow the air through the back coil from the inside out. The part of the coil that gets dirt on it is on the inside facing the fan. When the ac unit isn't able to blow enough of the heat out, it makes too much pressure, this overloads the compressor, causing the amps to rise. Make sure the rear coil is clean and the fins are straight and not folded.
Listen to this guy, almost guarantee that's your problem.
