bren0035
Jul 08, 2017Explorer
I did plug in a voltage meter and when the a.c. was running well the volltage was around 113-114...when mid day hit and weather was heasting up the voltage dropped to around 100 and that's when the a.c. souls start tripping. If get a new a.c. unit if I was sure that was the fix and not just an electric issue. Also, the main a.c. is on a tandem 20 amp breaker in the main 30amp fuse box. The back a.c. is on its own 20 amp breaker that is separate from everything else.
I'm new to this but does low voltage mean the a.c. will pull more amps?
