claymcc's avatar
claymcc
AC unit choice for AF 992
Hi all -
We've got a new AF 992 order, with a build date sometime in late January, and I want to get a low-profile AC unit on it so that I hopefully will be able to get it into my 12' clearance garage. My current AF 811 is too high (due to the AC unit) by a couple of inches.
Our dealer checked with Northwood, and basically what they said is that I have 2 choices if I don't want the 11k btu standard unit:
•13.5K 47203A876 Mach 8
•9K 47201A876 Mach 8 Cub
(11K is not available in Low Pro)
Northwood said that Onan says that the 2.5 Gen will not run the 13.5 A/C, so if I choose to go that route they won't warranty it.
My dealer (in Wyoming) says "for years the 2500 Onan LP gen has run 13.5 BTU AC's for us. But a year ago Northwood was getting many complaints from dealers saying that for customers in high elevation the 2.5 Onan would not run the AC. We have never come across this but I guess its a thing."
I don't use the AC all that incredibly often, but I do have to head to the Gulf Coast in summer sometimes, and I spend many nights camping in rest areas in hot weather when I need the AC to be run by the genset. If I'm taking a trailer - which most often happens when I'm actually using the rig for camping - I'd have my EU3000 that would run the 13.5k with no issue, and is a lot quieter.
So if I need to run the AC in hot weather off the Onan, I'd most likely be at lower altitudes and on a road trip, and if I'm camping, I'll most likely be at higher altitudes and have the Honda anyway.
Would the 9k cool the camper just fine anyway, or would I be giving up something significant by downsizing to it? What would you folks do?
- Clay
  • Seems like a straight forward answer. According to your research only the 9200 unit will fit and that's really a priority to you. I would imagine that the 9200 would handle your cooling needs most of the time. So unless you plan on visiting Las Vegas or Phoenix during the summer I bet you'll be ok.
  • My 11,000 will freeze us out in our AF 1140. With the way AF TCs are insulated, I would not be afraid to try out the 9000 BTU A/C
  • The 9200 btu unit will handle Wy. Summer temps. If you don't camp in temps higher than low 90's, I'd go with the 9,200.
