Old-Biscuit
Jul 11, 2013Explorer III
Sounds like evap cooler drip pan drain holes are plugged.
As the 'hot' air from inside rig gets pulled thru filter and evap cooler it gives up its heat........as air cools moisture drops out of it. The moisture collects in evap cooler drip pan which has drain holes so the moisture can flow out on to roof (or drain lines on some installations).
If the moisture can not drain out it will get carried over in air stream by the blower and will then drip out of discharge grill.
Dirty air inlet filter, dirty evap cooler, running fan on low speed setting can also cause water collection.
Go up on roof, remove shroud then remove cover over evap cooler.
Clean evap cooler & drip pan/drain holes. Clean condenser cooler also. Then reinstall cover/shroud.
Routinely change/clean inlet filter.
The 'hold down' bolts mentioned secure the A/C unit to roof. They should only be 'snug'. Over tightening will crush/warp roof gasket leading to leaks and need for replacement of roof gasket.
The roof gasket keeps rain etc. from leaking into rig around roof opening.
44,069 PostsLatest Activity: Jul 05, 2026
