sign_man
Nov 07, 2013Explorer
ac unit
1)i am looking to purchase an ac unit for my 815 tc. i want to be able to run it with a honda 2000 gen. i frequent temps in the 95+ range. anyone have this setup, and is it sufficient enough? 2)als...
Testudo wrote:
Find info on the POLAR CUB, ---->here
PPL Motor Homes seems to be currently selling POLAR CUB 9201's (and at a sale price). The data sheet indicates that it still pulls max amps of less than 9. The HONDA EU2000i is rated to produce about 16.6 amps for a short time (let's say a half an hour). The 'cruising speed' of the HONDA is ~13.3 amps (80% of 2,000 watts).... AT _SEA_ LEVEL!
When you go up in altitude, you have to derate the HONDA. At seven or eight thousand feet you might not have enough amps to run a larger converter to charge your batteries. That's why it is important to have the equipment to monitor the amp load of your electrical system. You can take non-essential equipment offline if your wiring is arranged thusly. In the worst case, you should at least have a device to monitor your voltage (at a camper outlet). If your measured voltage is falling below 110 volts, you are in trouble.
