Gsragtop
Jun 29, 2014Explorer
I'm going to try and clear things up.. The front of the units, sucks and blows as it should.. The back of the unit is vented outside the coach and is where the condenser is..
There are however ribbed vents on both sides of the unit (as with all window ac units) and these vents are not open to any real airflow.. I had assumed the roof vent allows airflow into the box that houses the ac unit.. That is why I was surprised to see no holes for the box to vent out of.
If it helps this is the unit I got
http://www.walmart.com/ip/Whirlpool-High-Efficiency-12-000-BTU-115V-Window-Mounted-Air-Conditioner-with-Remote-Control-ACQ128GPW/25394510
44,060 PostsLatest Activity: Mar 26, 2026
