noteven's avatar
noteven
Explorer III
Jul 10, 2020
Achates opposed piston engines
Ya I know they are never going to happen, (see Cummins military engines) won’t work, battery electric will take over first, etc etc
But it would be fun to have one of these to enjoy the distinctive sound of a turbo-supercharged 2 cycle engine...
Achates powered F-150
  • Probably wouldnt pass the emisions..two stroke run too dirty
    Heres a better engine
    working on completely new thermodynamic cycle in which Power stroke is Longer then Intake and Exhaust stroke making for improved power
    11 cyl one intake one exhaust no valves,no cams no crank.
    Ive seen this thing run in big car with 4 speed tranny back then when Kristiansen and his team invented it in 77
    http://www.freepatentsonline.com/RE30565.html
  • Lwiddis wrote:
    Opposed as in similar to my 1965 Corvair Monza Spyder?
    In your Monza the cylinders are opposed to each other. In the Achates engine there are 2 pistons opposed to each other in the same cylinder. No head or valves but a crankshaft at each end of the cylinder. Ports for breathing like in a typical two stroke engine. A supercharger is used to force air through the ports. It has been around for many years, mostly in marine engines.
    N0, not even close.
  • Opposed as in similar to my 1965 Corvair Monza Spyder?
