S__Rocky's avatar
S__Rocky
Adapter sleeve for 2 1/2 receiver
My new truck has a 2 1/2" receiver and my camper is a 2". Is it safe to use the adapter sleeve? I am having trouble finding a 2 1/2" replacement shank for my Reese weight distribution head. The holes on the shank for my distribution head are 1" apart.
Any thoughts?
  • I used one with my truck/trailer for the first season I had it. Found there was way too much slop. Got a 2.5 inch shank and I am much happier with the tow.
  • Tractor Supply unit rated for? And is that sufficient?
    And in regard to "a caution on the sleeve says do not use with distribution type hitches. Not sure why because it pulls fine." These are lawyer words. If it fails...you lose...cuz you used a product outside of its intended use, heard the warning and disregarded. And it will probably pull fine...until it fails...then you lose. Trust me, Lao didnt know anything about RVs or attorneys.
  • I don't know of a rating but a caution on the sleeve says do not use with distribution type hitches. Not sure why because it pulls fine.
  • Etrailer sells one but I believe it reduces the package from Class 5 to Class 4.
