rv46 wrote:
I would like to add a dedicate outlet for high draw items (hairdryer, heater, griddle, etc.) The plan is to a add an inlet and route the wire directly to this one outlet. However, I don't want to solely rely on the breaker on the post.
I saw this in a hotel. I looked at HD, Lowe's and two local electrical distributors with no luck. I would prefer 15A/20A breaker.
Any ideas where to find this? Alternatives?
When I installed my second 30A service supply I fed that into a 60A "Load Center" shown below with two 15A CB each of which protected a single duplex outlet inside the trailer. The Load Center is available from either Lowes or HD and runs around $20 (less the breakers). I mounted my new load center in my rear pass thru which was the easiest location for my particular needs.
The little dark grey cover is something I added so the CBs were a little more protected since they were in the pass thru where stuff is stored.
Larry
