BossCamper
Jun 15, 2013Explorer
MackinawMan wrote:BillB800si wrote:
Just traded in a 2007 Jayco Eagle 322FKS trailer (on a 2014 Cougar HC 321RES trailer) had way over 25,000 miles on it. Greased the axles each year (EZ lube zerk fittings) and never had a problem..
Happy trails,
Good to hear...I've always used the EZ lube zerk fittings too...didn't realize I was doing something wrong.;)
You're not doing anything wrong. Some folks get EZ lube axles and Bearing Buddies confused. With Bearing Buddies, it`s really easy to over lube! EZ lube is a great way to make sure your grease is topped up.
Of course.... manually repacking bearings is better than just depending on EZ lube alone, because you get to inspect the brakes, bearings, and axle.
44,060 PostsLatest Activity: Mar 28, 2026
