kevden wrote:
Our TT has an outside kitchen. I installed an inverter to power the fridge while traveling. The Trucks alternator keeps the battery charged while driving, so no worry about the inverter draining the TT battery. I put in a 1750 watt inverter, but I have read that an 800 watt unit will work. The fridge uses much less than that while running, but needs a higher wattage to start the compressor.
I've been considering the same floor plan. I also considered adding the inverter to keep that little fridge going but I was concerned there isn't enough air space for the fridge to run and cool while the outside door is closed.
I take it you've had no problem with it?
Thanks,
Scott
