PassmeExplorerMay 01, 2017Adding batteriesWell my WF-9855 converter is behaving just like everyone says, no bulk charge available regardless of SOC. And as usual it's gotta be the garbage factory wiring, it's 20+ ft. to tongue mounted Interst...Show More
time2rollNomadMay 02, 2017Replace the 9855. Even with 4 batteries and monster cables you will be hard pressed to get boost mode from a WFCO. BTDT.PD9260-14.8 from bestconverter.com might be the best solution and could probably use existing wire.http://www.bestconverter.com/PD-9260C-148-60-Amp
Related ContentAdding power outlets in slide with no wiringAG battery switchoverAdding more batteriesAdding a second battery?Adding Batteries / Refer Support
