- Old_DaysExplorer III just put another 100 watt panel on my 811. I have put solar on before and I have had good luck with Renogy products. The charge controller that Northern Lite installs at the factory is a pretty good one.
- scout4troutExplorerWe added a 100 watt panel last summer to our Northern Lite and it really made a difference. Lots of info about adding panels on the Facebook NL group.
- LwiddisNomad IIWhat wire size did the manufacturer use and what is the length of the run from the panel to the controller? Is your controller rated to handle the additional amps?
- naturistNomad IISame voltage, different amperage, put them in parallel. Same amperage, different voltage, put them in series.
- Camper_Jeff___KNavigatorI have an old 67 watt thin film Unisolar panel. I added a new 170 watt GoPower mono crystal panel. Both have the same voltage rating and have worked very well together for about a year now. Or splurge and get two new panels.
- pianotunaNomad IIIIn a perfect world the added panel should be identical. In real life, if the voltage is less than one volt different, it may work well in parallel.
44,066 PostsLatest Activity: Apr 15, 2026
