Lynnmor
Feb 27, 2017Explorer II
You shouldn't need washers, the instructions should be with your wet bolt kit. I replaced all my cheap spring nuts with high quality lock nuts so that they don't smash into the small shoulder so far.
The LCI page you posted shows pieces added between the hangers like the X-Factor parts I mentioned. The X-Factor wouldn't be as stiff as the welded tubing, but it is easier and can be removed if necessary. I built my own bolt in system.
44,070 PostsLatest Activity: Jan 14, 2013
