DoxieBox's avatar
DoxieBox
Adding insulation WITHOUT tearing up the rig??
Just got a used 31' trailer w/ 2 slide outs and ONE, yes, 1 roof A/C. Still haven't determined BTU of said A/C...need to locate that info. We will be using it for the first time in about a week at Lake Havasu, AZ. I already know, it's gonna get HOT in there.
I have combed the Innerwebz for ideas on keepin my cool, and already picked up some Reflectix for the windows and inside cabinets that back to outer walls, obtained a few shade sails to place strategically outside for shade, and will go get a portable A/C that vents out a window (anyone do that and have tips??) I will be ripping out the carpet and vinyl flooring to redo with wood laminate...hoping a beefy underlayment aids with this as well.
What I'd like to figure out: IS there a way to add some more insulation to the hot box WITHOUT ripping into the walls and such?? I'm so afraid of the extreme temps, that I'm almost willing to sacrifice aesthetics and just roll that Reflectix right over the walls during Summer! ALMOST.
GO.... (and thanks!;)
  • A portable AC that vents out a window will draw HOT air in from outside. I had a portable when our central quit in the stick and brick, and while it did blow out cool air it did not work very well at all. A floor fan to circulate the air helped but I was real happy to get a new central unit.
    I don't think anything you do is going to make a big difference in very hot weather. Remember you are in a big aluminum box.
  • If your high-temp use is going to be a common thing, you should go ahead and invest in another AC unit.
    Otherwise, there is some stuff called Desert Shade Cloth, that people use at places like that. You could rig it overhead like a tarp.
    Found a link: Desert Shade Cloth
