theoldwizard1
Jan 04, 2020Explorer II
theoldwizard1 wrote:
Two big issues when trying to glue metal to wood.
• Preparation. The aluminum should be "scratched" a bit (ScotchBrite) and wiped down with acetone. Light sanding on the wood and a tack cloth.
• Expansion rates of the two materials. Aluminum expands a LOT when heated (sun exposure). Wood only expands a little when it is warmed. BAD COMBINATION ! No adhesive can survive that for long periods !!Aubrey0418 wrote:
Also it's a 16ft camper so we will have to find a way to apply adequate even pressure throughout while laying the roof down..any suggestions on that?
Lots of cinder blocks or other heavy weights.
Best solution Hex self tapping stainless sheet metal screw w/sealing washer These will hold in plywood.
Shop for similar WITHOUT the rubber washer and you can buy those cheap.
44,071 PostsLatest Activity: Aug 16, 2026
