theoldwizard1
Jan 05, 2020Explorer II
Gdetrailer wrote:badsix wrote:
why not use the EPDM rubber roofing material used on most RVs. its probably not much more than aluminum in cost and probably easier to install. use Dicor self leveling sealer for any penetrations and you'll be good to go. I sure wouldn't want an aluminum roof with screws of any kind in it if I was looking for long life. Google RecPro, Dicor EPDM roofing
Jay D.
Because "EPDM" and any other flexible non metallic roof solution is a short lived 10yr-15yr fix.
You are GENEROUS in predicting 10-15 years. MAYBE if you wash it a couple times each year, apply a UV protectant every time it is washed and store it out of the sun.
NRALIFR wrote:
I would also pass on the EPDM, TPO, or any other flexible membrane roofing. Nothing beats aluminum.
You might convince me of TPO if it is installed by RV Roof Install. They give a 20 year warranty.
