DWeikert
Jan 21, 2017Explorer II
work2much wrote:
...I believe that if you used a combo of adhesive and covered them with a good swath of eternabond tape over the feet and down to a clean roof that they would stay in place. Any one that has tried to remove eternabond tape knows that stuff is tenacious to say the least.
That would firmly attach the panel to the roof, but do you know how firmly the rubber roof is attached to the structure underneath? A lot easier to seal a few screw heads firmly attaching the feet than replace a rubber roof that the panels peeled off the camper at 70 mph.
I ran screws through the feet firmly attaching the panel to the roof. Some eternabond tape under the feet and screw head with Dicor liberally applied above. I have doubts the typical rubber roof installation is meant to survive the lifting force the panel could apply to the roof.
