eHoefler
Jun 16, 2015Explorer II
Simply, no. The axles would have to be removed from the frame, and install a different set with the proper drop or lift. If you already have the set with the lift, you would have to remove the axles from the frame and have a spacer welded on the frame ant the axles re-installed.
44,068 PostsLatest Activity: Jun 17, 2026
