Sam_WhiskeyExplorerJun 15, 2015Adjusting height on Dexter Torflex AxlesRe: 93 Coachmen TT. Seems the trailer is too low as the holding tank connections are only a few inches off the ground. Is there a way to adjust the height on these axles? Thanks!!Show More
We_Cant_WaitExplorerJun 16, 2015One way to raise the camper higher is to lighten the load. Have you weighed you unit to see if you're over gross?
Related ContentBall Height Adjustment Questionsheight adjustmentTrailer hitch height adjustment and chain questionHow to adjust LED headlights?arctic fox slide adjustment
