HNTucker's avatar
HNTucker
Advance on Travel Trailer
Hi, I’m new to the RV world. I have a grand Jeep Cherokee 2011 with the V6 engine with tow package. I have settled on two very different travel trailers. One is 1100 pounds dry weight 13 feet in length and the other is 1800 dry weight and will likely be 2800 pounds max when fully loaded 17 feet in length. I have zero interest or ability to upgrade my vehicle at this point. It will be myself and the dog crew traveling.
Question 1: Will the larger trailer put too much stress on my vehicle over time at that weight
Question 2: I heard that smaller trailers are actually harder to back up , so would the larger trailer actually be easier to navigate
And Lastly Question 3: Would boondocking be reasonable with either length?
Any advice is welcomed
Thanks in advance
  • HNTucker wrote:
    Jeeps Max payload is 2030
    Fresh water And grey tank on the little guy- 5 gallons
    Fresh water And gray on the big guy- 17 gallons
    No black water tank
    I'd love to see proof of an actual Jeep with 2030lbs of payload capacity.:R
  • Jeeps Max payload is 2030
    No black water tank
  • The other TT “usables” are electricity and propane. A bottle of propane lasts a long time if you don’t use the heater and electricity can be generated....hopefully by a quiet solar system.
  • Great, thank you for the replies! Again I’m new, and I’m looking at the happier camper:) it allows me to gut the inside for bikes, kayaks , and pets if needed . It seemed to be even lighter with slightly more versatility than the scamps/casitas for my needs.
    I’ll have to look up the overdrive lock out and see what you mean. Send any links you think may be helpful:)
    Thanks!
  • You can go up another 1000 or so dry and have absolutely no issues.
  • Sounds as if you might be looking at Scamps or Casitas, considering the sizes and weights you propose. Did I guess correctly? :)
    The longer trailer punches just about the same hole in the air as the shorter one, so you shouldn't have any difficulty with either one. The 3.6L V6 has enough power to do the job. With the old 5-speed auto, you probably have an overdrive lockout that you'll want to engage while towing to avoid excessive torque converter heat in the tranny.
    Backing either trailer is a matter of practice. The shorter one will swing to the side a tad faster than the longer trailer, but not a huge difference.
    As for boondocking, size is not much of an issue. But if your fresh water tank is small, you may need to carry extra water (jerry cans work well) depending on how long you want to be in one spot. Pay attention to ground clearance if you plan to boondock along rough forest roads.
  • Within reason, longer the TT the easier it will be to backup.
    What’s the Jeep’s max payload and what’s the weight you’ll be carrying in it?
    Max time boondocking is determined by the amount of fresh water and holding tank capacity. What size tanks do these two have?
  • Either trailer would be fine with your vehicle, but...
    You’ll likely need a trailer brake controller and 7 pin connector with the larger one. The smaller trailer likely does not have trailer brakes and a four pin connector for lights is all that is needed. Most, if not all, states do not require trailer brakes under 2000# GVWR and many don’t require them until 3000# GVWR. A Weight distributing hitch would be nice for the larger trailer if it squatted your SUV much, not needed with the smaller one.
    I towed a 3877 GVWR TT with a V6 Ford Explorer V6 with tow package. Engine was a little weak on steep or long hills But elsewise fine towing that. I did use a weight distributing hitch.
    Smaller length single axle trailers are easier to jackknife when backing. Just expect it and go easy and slow while backing.
    I own a small 2000# 4x4x8.5’ cargo trailer & it is real easy to jackknife. My previous 2995# GVWR (on 3500# axle, no brakes) 10x6x6’ cargo trailer was also easy to jackknife.
    Just don’t be in a hurry when backing up. Like the Shootist said, “slow is smooth, and smooth is fast”. That also applies when backing a trailer. Take your time and the end result will actually be faster than pulling forward a lot to straighten out, with less frustration.
  • There is not enough length difference in those two to matter at all when backing.
    I can’t comment on if your suv will be ok towing it or not, but soon enough you will get some advice on that.
