HMS_Beagle
Sep 01, 2016Explorer II
Gelcoat used under fiberglass moldings tends to oxidize and turn to "chalk" in time. If you run your fingers or a dark cloth across it do you get a white powder?
There isn't really an easy cure, compound it will remove the surface oxidation, but it must be kept waxed from then on. Or paint the cap with polyurethane.
