wally665
Feb 25, 2015Explorer
Advice from F250/F350 SRM Owners with HEAVY truck campers
Hi,
I am looking at purchasing a Camplite 10 Truck Camper next year. The dry weight is 2290lbs, however I have read adding the 4 seasons kit adds 500lbs so after loading it up I am thinking it will weight around 3000lbs at least.
I have a early 1999 f250 super duty crew cab long bed diesel rwd truck. While the window sticker says it was equipped with the camper/trailer package the spring code on the door sticker is "LA" and does not have overload springs in the rear or a sway bar. Per ford my max payload is around 1700 with a person in every seat. Since only my wife and I will be in the truck that will add more weight to the payload. The truck currently has 265 Goodyears rated for 34XX lbs I believe.
I dont want to bring up the debate of gvwr.
Does anyone else run a heavy camper on a f250/f350 srw? If so what modifications have you made to your truck?
As of now I am leaning towards the roadmaster active suspension, big wig rear sway bar and possibly airbags.
Looking for some advice from someone who has a similar rig!
Thanks!
Thanks!
