BobsYourUncle
Jul 05, 2013Nomad
turtletalk wrote:
Actually, I have only the glass out like taking a windshield out. I have used Butyl tape for replacing an entire window unit but this time have just the glass out. What do you think? I scraped off very gooey black stuff. David
Oh that makes things different! Very different - I thought you had the whole window out.
Toss out the previous ideas now.
Glass is held into the window frame with glazing tape. There have been many transitions in the methods for glazing windows.
Years ago they used to use black butyl tape, roughly 3/8" X 1/16". The size varies a bit. This stuff sticks really well, but oozes and the glass can actually move in the frame. The hotter it gets the softer the butyl becomes. It is still available and is still used in some applications.
What is more common now, especially in residential applications, is foam glazing tape. Same size, but it does not ooze and the glass does not migrate using this tape.
Tape is 2 sided - once the glass is in the frame, there is a trim strip to finish it off. Sometimes rubber, if curved corners, sometimes aluminum.
