1handyhubby's avatar
1handyhubby
Advice needed on F350 V10
I finally found the V10 I was looking for. 2001 F350 Lariat dually, crew cab, 4x4. All the bells ansd whistles. Excellent shape. Bilstein gas shocks, Firestone airbags with onboard compressor, oversize tires, the works. I talked to several people who said gas milage would be around 14 mpg. I've never been a gearhead so didn't know much about the larger rear ends. The owner thought it had 411, the book says 430. All I know is I was a little shocked when the gauge showed 6.9 mpg. ?? Besides a K & N cold air intake, which will be my first purchase, what can I do for better mpg? Had I known about the milage I probably wouldn't have bought it. My fault for lousy research. Sorry for the long winded intro. Thanks.
  • It really all depends on how it hauls. If you find it stays in top gear for most of the time, it's saying over geared. But if you find it shifts down readily on slight hills, it's geared about right.
    I get 10 to 11 with my 7.3 in US gallons
  • Save your money on the K&N. It won't do anything positive enough to justify the cost.
