Terryallan
Nov 02, 2015Explorer II
Chuck_thehammer wrote:
I would TRY to drain the fresh water tank... as dealer may have put water in it to test the pump... better Safe then sorry...
if NO water in tank the pump should also be dry.
Agree. Most all dealers fill the fresh tank, and run water thru the pump for the walk thru. If you bought it new. Weather you used the fresh tank or not. It had water in it, and water was ran thru the pump. Under the tank is a drain, and it is not the low point drain, only the tank drain. And you will need to get the water out of the pump as well. If not, the seals could freeze. I run a little pink thru it. And drain the fresh tank.
44,066 PostsLatest Activity: Jul 25, 2018
