MFL
Mar 27, 2016Nomad II
Cummins12V98 wrote:
A lot of pin boxes when adjusted up or down may have less holes for bolts to go into making the rating much less. Best to set hitch at highest setting tow the RV home and adjust hitch height so you have a minimum of 6" bed clearance at the tailgate.
Good advice here!
With the added height of the picture frame, you may not need to set hitch to highest position. I would set it just below the bed rail level to start. This should give you the 6"s or more clearance needed.
Jerry
44,066 PostsLatest Activity: Mar 14, 2015
