phillyg
Mar 27, 2016Explorer II
Thanks, Me Again. I do seem to remember seeing some adjustment bolts on the pin box. Is there any disadvantage to having the 5th wheel hitch adjusted to its maximum height while the pin box is in its lowest position, or vice versa?
I recommend you have the necessary tools to adjust your hitch height if possible. You should really have two people available to adjust the pin box because of its weight. OTOH, I would try to have the dealer make the hitch/pin box adjustments when you go in to pick up the brand new FW you bought from him.
44,066 PostsLatest Activity: Mar 14, 2015
