Gdetrailer
May 06, 2018Explorer III
chrisdd23k wrote:
I bought w new Coachman 292BHDS Travel Trailer last summer. The TT dry weight is 6,150 lbs. Now I am looking to buy a new pick up truck to tow it, either a Ford F150 of a Chevy Silverado 1500. Both trucks have different configurations that range in tow capacity. Chevy has one that tows 9,100 lbs or 11,100 with max tow package. Ford has similar ranges including some at 10,500. How much max tow capability will I need?
Other Weight Factors
2 adults, 3 teenagers and a dog about 700lbs
gear roughly 800lbs
tanks are empty when traveling
food/drinks 200lbs
Your easily well above the available cargo of either 1/2 ton truck once you add in passengers and extra gear.
6,150 lb empty trailer at 15% tongue weight is 922.5 lbs.
700 lbs for passengers and dogs plus 922.5 lbs is 1622.5 lbs..
You forgot WD hitch, that is about 100 lbs that will take away cargo of the vehicle.
You virtually have ZERO cargo available to load the trailer with "gear", food, drinks or any other needed camping stuff.
That is pretty much the limits of 1/2 ton cargo..
The only exception I can think about is if you bought the lowest trim level F150 in a regular cab 4x2, eco boost with max tow, max payload and then you might have about 2200 lbs of cargo..
But with you having so many passengers plus dogs you will need Crew cab (minus cargo), you will most likely insist on 4x4 (minus cargo), and top level trim (minus cargo)..
People buy into those Max towing numbers without realizing that those numbers ARE based on the BASE VEHICLE which means Standard cab, short bed, 4x2, NO OPTIONS that do not increase payload.
#1 rule is you WILL run out of tow vehicle payload before you reach any other limit..
That trailer when loaded would be a much better match with a 3/4 ton..
My 2013 F250 super cab 4x2 with 6.2 has 3451 lbs of available cargo.. Mine would tow that trailer with ZERO issues..
In fact, I am towing a trailer that when loaded is 6500 lbs plus an additional 15 gallon fuel tank, plus a 100 lb generator, 200 lbs of campfire wood, three bicycles and several hundred lbs of misc tools and other camping stuff in the bed of my truck..
Tows nicely and I don't have to weight every potato chip I take with me :B
I should also mention that a fully loaded F150 with eco, max tow and max payload CAN cost much more than a modestly optioned XLT F250.. I have seen numbers for eco F150s as much as $60K and yet my 2013 F250 was just about $42K out the door..
Recently priced out a similar 2018 F250 at about $45K.. Pretty good chance that to get enough F150 to handle that trailer you will be north of $65K..
44,056 PostsLatest Activity: May 04, 2014
