bid_time
May 11, 2018Nomad III
rbpru wrote:so let me see if I got this right. Just because your 1/2 ton only has 1411 lbs of payload everyone else most have only 1411 lbs of payload. What if he gets a 1/2 ton with 2000 lbs of payload? By my calculations your 5000 lbs dry weigh is full of sheet.
Well by now the OP should know that a pick up can pull a lot more than it can carry. My 2010 F-150 can pull 9500 lbs. but the max cargo means it can only carry 1411 lbs. And, each vehicle is different depending on the features it left the factory with.
Of my 1411 lbs. of cargo capacity two adults, a big dog, bikes and other toys eat up about 700 lbs. leaving 711 lbs. for the tongue weight.
The hard fact is a half ton pick up is good for about a 5000 lb. dry weight TT, when both are loaded for the road.
I have never found braking to be a issue with properly adjusted TT brakes, even in the Rockies.
44,056 PostsLatest Activity: May 04, 2014
